Delay
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
| avocado (2.0-6) |
11.9 |
11.9 |
| Bollie (2.6-6) |
13 |
13 |
| Bollie Delay XT (0.1-1) |
13.1 |
11.8 |
13.5 |
13.5 |
15.8 |
15.8 |
16.2 |
16.2 |
| Gaffa (1.1-4) |
18.9 |
18.9 |
| TTAP (2.2-13) |
25.6 |
25.6 |
| MDA DubDelay (0.7-16) |
12.2 |
12.2 |
| floaty (2.0-10) |
14.2 |
14.2 |
| dm-GrainDelay (0.0-4) |
16.7 |
16.7 |
| Granulator (1.0-6) |
20.2 |
20.2 |
| GxDelay-Stereo (28.3-24) |
12.7 |
12.7 |
| Gxdigital_delay (28.3-24) |
13.8 |
13.8 |
15.9 |
15.9 |
| Gxduck_delay (28.3-24) |
11.9 |
11.9 |
| Gxduck_delay_st (28.3-24) |
15.4 |
15.4 |
| GxEcho-Stereo (28.3-24) |
12.4 |
12.4 |
| GxEchoCat (28.3-23) |
15.7 |
15.7 |
18.4 |
184 |
11.8 |
11.8 |
11.8 |
11.8 |
Distortion
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
| Open Big Muff (0.0-8) |
17 |
17 |
| CollisionDrive (1.3-2) |
17 |
9 |
| MDA Degrade (0.2-4) |
10 |
10 |
| DS1 (0.0-8) |
19 |
19 |
| GxBaJaTubeDriver (35.0-5) |
12 |
9 |
12 |
12 |
| GxFuzzFaceJH-2 (28.3-24) |
13 |
13 |
| GxHogsFoot (28.3-24) |
10 |
10 |
| GxHyperion (28.3-8) |
10 |
10 |
| GxKnightFuzz (34.0-8) |
11 |
10 |
| GxMole (28.3-24) |
10 |
10 |
| GxRangemaster (28.3-24) |
10 |
10 |
| GxSD2Lead (34.0-5) |
13 |
10 |
| GxTubeScreamer (28.3-24) |
11 |
11 |
Dynamics
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Filter
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
| TAP Equalizer (7.2-11) |
10 |
10 |
| TAP Equalizer/BW (7.2-11) |
11 |
11 |
13 |
13 |
14 |
14 |
| rkr Parametric EQ (0.0-7) |
12 |
12 |
Generator
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
MIDI utilisty
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Modulator
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Reverb
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Simulator
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Spatial
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Spectral
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Utility
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
11.6 |
11.6 |
11.6 |
11.6 |
9.1 |
9.1 |
| Gain (1.0-18) |
11.6 |
11.6 |
| Gain 2x2 (1.0-18) |
11.8 |
11.8 |
| TinyGain Mono (770.0-7) |
14.6 |
14.6 |
| TinyGain Stereo (770.0-7) |
14.9 |
14.9 |
| Volume (1.0-7) |
11.5 |
11.5 |
| Volume 2x2 (1.0-7) |
11.6 |
11.6 |
| Level Meter (0.0-1) |
11.3 |
11.3 |
| LP3 Basic (1.0-15) |
16.1 |
14.6 |
| Metronome (1.0-5) |
9 |
9 |
| Mixer (2.0-4) |
22.2 |
22.2 |
| Mixer Stereo (2.0-4) |
34.1 |
28.4 |
| Notes (2.0-3) |
8.2 |
8.2 |
| Spectrum Analyzer (1.0-1) |
9.5 |
9.3 |
| Stereo X-Fade (516.0-6) |
11.8 |
11.8 |
| Switchbox 1-2 (1.1-18) |
11.4 |
11.4 |
| Switchbox 1-2 ST (1.1-6) |
12.2 |
12.2 |
| Switchbox 2-1 (1.1-6) |
11.6 |
11.6 |
| Switchbox 2-1 ST (1.1-6) |
11.8 |
11.8 |
| SwitchTrigger4 (1.1-12) |
11.9 |
11.9 |
| ToggleSwitch (1.1-18) |
12 |
12 |
| Instrument Tuner (0.0-1) |
77.3 |
58.4 |
