Plugins CPU Usage
Revision as of 11:01, 28 February 2023 by Rom (talk | contribs) (→‎Delay)
This will obviously not be very accurate but the intention is to have an estimation and especially be able to compare plugins so it's important that users who contribute to this page use the same method of measurement. Keep in mind the numbers include the CPU usage of the idle unit (without any loaded plugin) so adding the numbers of several plugins doesn't work :
  • First of all, we should 'disable optional processing' on the device settings (noise gate, compressor and ground loop compensation).
  • Next, put the plugin alone on the Constructor.
  • Connect the plugin input(s) and output(s) to the hardware ones.
  • Note the CPU usage displayed on the Web interface when the plugin is On and Off.
Delay
Plugin (version) Dwarf % On Dwarf % Off Duo X % On Duo X % Off Duo % On Duo % Off
avocado (2.0-6) 11.9 11.9
Bollie (2.6-6) 13 13
Bollie Delay XT (0.1-1) 13.1 11.8
Calf Vintage Delay (60.0-8) 13.5 13.5
Invada Delay Munge (mono in) (2.1-8) 15.8 15.8
Invada Delay Munge (sum L+R in) ( 2.1-8) 16.2 16.2
Gaffa (1.1-4) 18.9 18.9
TTAP (2.2-13) 25.6 25.6
MDA DubDelay (0.7-16) 12.2 12.2
floaty (2.0-10) 14.2 14.2
dm-GrainDelay (0.0-4) 16.7 16.7
Granulator (1.0-6) 20.2 20.2
GxDelay-Stereo (28.3-24) 12.7 12.7
Gxdigital_delay (28.3-24) 13.8 13.8
Gxdigital_delay_st (28.3-24) 15.9 15.9
Gxduck_delay (28.3-24) 11.9 11.9
Gxduck_delay_st (28.3-24) 15.4 15.4
GxEcho-Stereo (28.3-24) 12.4 12.4
GxEchoCat (28.3-23) 15.7 15.7
GxMultiBandDelay (28.3-24) 18.4 184
the infamous stuck (0.1-13) 11.8 11.8
the infamous stuck stacker (0.1-13) 11.8 11.8
Distortion
Open Big Muff (0.0-8) 17 17
CollisionDrive (1.3-2) 17 9
MDA Degrade (0.2-4) 10 10
DS1 (0.0-8) 19 19
GxBaJaTubeDriver (35.0-5) 12 9
GxColorSoundTonebender (28.3-24) 12 12
GxFuzzFaceJH-2 (28.3-24) 13 13
GxHogsFoot (28.3-24) 10 10
GxHyperion (28.3-8) 10 10
GxKnightFuzz (34.0-8) 11 10
GxMole (28.3-24) 10 10
GxRangemaster (28.3-24) 10 10
GxSD2Lead (34.0-5) 13 10
GxTubeScreamer (28.3-24) 11 11
Dynamics
Filter
TAP Equalizer (7.2-11) 10 10
TAP Equalizer/BW (7.2-11) 11 11
x42-eq - Parametric Equalizer Mono (1.1-6) 13 13
x42-eq - Parametric Equalizer Stereo (1.1-6) 14 14
rkr Parametric EQ (0.0-7) 12 12
Generator
MIDI utilisty
Modulator
Reverb
Simulator
Spatial
Spectral
Utility
