Delay
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
| avocado (2.0-6) |
11.9 |
11.9 |
| Bollie (2.6-6) |
13 |
13 |
| Bollie Delay XT (0.1-1) |
13.1 |
11.8 |
13.5 |
13.5 |
15.8 |
15.8 |
16.2 |
16.2 |
| Gaffa (1.1-4) |
18.9 |
18.9 |
| TTAP (2.2-13) |
25.6 |
25.6 |
| MDA DubDelay (0.7-16) |
12.2 |
12.2 |
| floaty (2.0-10) |
14.2 |
14.2 |
| dm-GrainDelay (0.0-4) |
16.7 |
16.7 |
| Granulator (1.0-6) |
20.2 |
20.2 |
| GxDelay-Stereo (28.3-24) |
12.7 |
12.7 |
| Gxdigital_delay (28.3-24) |
13.8 |
13.8 |
15.9 |
15.9 |
| Gxduck_delay (28.3-24) |
11.9 |
11.9 |
| Gxduck_delay_st (28.3-24) |
15.4 |
15.4 |
| GxEcho-Stereo (28.3-24) |
12.4 |
12.4 |
| GxEchoCat (28.3-23) |
15.7 |
15.7 |
18.4 |
184 |
11.8 |
11.8 |
11.8 |
11.8 |
Distortion
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
| Open Big Muff (0.0-8) |
17 |
17 |
| CollisionDrive (1.3-2) |
17 |
9 |
| MDA Degrade (0.2-4) |
10 |
10 |
| DS1 (0.0-8) |
19 |
19 |
| GxBaJaTubeDriver (35.0-5) |
12 |
9 |
12 |
12 |
| GxFuzzFaceJH-2 (28.3-24) |
13 |
13 |
| GxHogsFoot (28.3-24) |
10 |
10 |
| GxHyperion (28.3-8) |
10 |
10 |
| GxKnightFuzz (34.0-8) |
11 |
10 |
| GxMole (28.3-24) |
10 |
10 |
| GxRangemaster (28.3-24) |
10 |
10 |
| GxSD2Lead (34.0-5) |
13 |
10 |
| GxTubeScreamer (28.3-24) |
11 |
11 |
Dynamics
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Filter
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
| TAP Equalizer (7.2-11) |
10 |
10 |
| TAP Equalizer/BW (7.2-11) |
11 |
11 |
13 |
13 |
14 |
14 |
| rkr Parametric EQ (0.0-7) |
12 |
12 |
Generator
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
MIDI utilisty
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Modulator
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Reverb
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Simulator
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Spatial
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Spectral
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Utility
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
