Delay
avocado (2.0-6) |
11.9 |
11.9 |
Bollie (2.6-6) |
13 |
13 |
Bollie Delay XT (0.1-1) |
13.1 |
11.8 |
Calf Vintage Delay (60.0-8) |
13.5 |
13.5 |
Invada Delay Munge (mono in) (2.1-8) |
15.8 |
15.8 |
Invada Delay Munge (sum L+R in) ( 2.1-8) |
16.2 |
16.2 |
Gaffa (1.1-4) |
18.9 |
18.9 |
TTAP (2.2-13) |
25.6 |
25.6 |
MDA DubDelay (0.7-16) |
12.2 |
12.2 |
floaty (2.0-10) |
14.2 |
14.2 |
dm-GrainDelay (0.0-4) |
16.7 |
16.7 |
Granulator (1.0-6) |
20.2 |
20.2 |
GxDelay-Stereo (28.3-24) |
12.7 |
12.7 |
Gxdigital_delay (28.3-24) |
13.8 |
13.8 |
Gxdigital_delay_st (28.3-24) |
15.9 |
15.9 |
Gxduck_delay (28.3-24) |
11.9 |
11.9 |
Gxduck_delay_st (28.3-24) |
15.4 |
15.4 |
GxEcho-Stereo (28.3-24) |
12.4 |
12.4 |
GxEchoCat (28.3-23) |
15.7 |
15.7 |
GxMultiBandDelay (28.3-24) |
18.4 |
184 |
the infamous stuck (0.1-13) |
11.8 |
11.8 |
the infamous stuck stacker (0.1-13) |
11.8 |
11.8 |
Distortion
Open Big Muff (0.0-8) |
17 |
17 |
CollisionDrive (1.3-2) |
17 |
9 |
MDA Degrade (0.2-4) |
10 |
10 |
DS1 (0.0-8) |
19 |
19 |
GxBaJaTubeDriver (35.0-5) |
12 |
9 |
GxColorSoundTonebender (28.3-24) |
12 |
12 |
GxFuzzFaceJH-2 (28.3-24) |
13 |
13 |
GxHogsFoot (28.3-24) |
10 |
10 |
GxHyperion (28.3-8) |
10 |
10 |
GxKnightFuzz (34.0-8) |
11 |
10 |
GxMole (28.3-24) |
10 |
10 |
GxRangemaster (28.3-24) |
10 |
10 |
GxSD2Lead (34.0-5) |
13 |
10 |
GxTubeScreamer (28.3-24) |
11 |
11 |
Dynamics
Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Filter
TAP Equalizer (7.2-11) |
10 |
10 |
TAP Equalizer/BW (7.2-11) |
11 |
11 |
x42-eq - Parametric Equalizer Mono (1.1-6) |
13 |
13 |
x42-eq - Parametric Equalizer Stereo (1.1-6) |
14 |
14 |
rkr Parametric EQ (0.0-7) |
12 |
12 |
Generator
Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
MIDI utilisty
Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Modulator
Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Reverb
Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Simulator
Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Spatial
Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Spectral
Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Utility
Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
