This will obviously not be very accurate but the intention is to have an estimation and especially be able to compare plugins so it's important that users who contribute to this page use the same method of measurement. Keep in mind the numbers include the CPU usage of the idle unit (without any loaded plugin) so adding the numbers of several plugins doesn't work.
First of all, we should disable optional processing on the device settings (noise gate, compressor and ground loop compensation). Next, put the plugin alone on the Constructor. Connect the plugin input(s) and output(s) to the hardware ones. Note the CPU usage displayed on the Web interface when the plugin is On and Off.
Delay
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Distortion
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
| Open Big Muff (0.0-8) |
17 |
17 |
| CollisionDrive (1.3-2) |
17 |
9 |
| MDA Degrade (0.2-4) |
10 |
10 |
| DS1 (0.0-8) |
19 |
19 |
| GxBaJaTubeDriver (35.0-5) |
12 |
9 |
12 |
12 |
| GxFuzzFaceJH-2 (28.3-24) |
13 |
13 |
| GxHogsFoot (28.3-24) |
10 |
10 |
| GxHyperion (28.3-8) |
10 |
10 |
| GxKnightFuzz (34.0-8) |
11 |
10 |
| GxMole (28.3-24) |
10 |
10 |
| GxRangemaster (28.3-24) |
10 |
10 |
| GxSD2Lead (34.0-5) |
13 |
10 |
| GxTubeScreamer (28.3-24) |
11 |
11 |
Dynamics
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Filter
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
| TAP Equalizer (7.2-11) |
10 |
10 |
| TAP Equalizer/BW (7.2-11) |
11 |
11 |
13 |
13 |
14 |
14 |
| rkr Parametric EQ (0.0-7) |
12 |
12 |
Generator
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
MIDI utilisty
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Modulator
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Reverb
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Simulator
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Spatial
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Spectral
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Utility
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
