Troubleshooting Reinstall
MOD boots the main system, but screens do not work
If the MOD is able to boot (verified by still providing USB Ethernet device) but the screens do not seem to work properly, we can try to re-flash the "top-board"/screen controller unit.
reflashing controller via web interface
Open the [web interface advanced settings|http://192.168.51.1/settings.html] (accessible in the bottom-right corner of the regular web interface), then navigate to the "DANGEROUS" area. Simply follow the instructions for the "Reflash controller" section of the page.
reflashing controller via SSH
hmi-update /usr/share/mod/controller/mod*controller.bin
MOD does not boot
If your unit seems unable to boot properly, we can force the unit to start in restore mode.
- Turn off your MOD
- Hold the left knob and footswitch down (on the Duo X use the left endless-knob and the 1st button from the bottom-left)
- Disconnect the USB cable
- Wait while the unit updates itself, it will reboot automatically when done
MOD boots into recovery mode automatically
If this happens, we need to reinstall the latest release, which will allow the unit to boot normally again.
MOD does not boot at all, not even in restore mode
If you have a MOD Duo X unit that cannot boot normally or in forced-restore mode, please contact support@mod.audio.
This part of the troubleshooting section does not apply to the MOD Duo X, as it does not have a FEL button and thus cannot be forced to boot custom payloads.
