Duo X Technical Specs
Technical specs
  • length: 188 mm
  • width: 163 mm
  • height: 63 mm
Processors
  • RockChip RK3399 CPU:
    • CPU family: ARM A72 + A53
    • Platform bit depth: 64 bit
    • Cores Clock: 4 x 1.4GHz + 2 x 1.8GHz
    • Memory: 2 GB RAM
    • Flash Storage: 16 GB
Audio
MOD Duo X right side view showing the audio and CV inputs.
MOD Duo X left side view showing the audio and headphone/CV outputs.
    • independent multi-stage preamplifiers per channel (+6, +15, +20dB);
    • TS connectors;
    • Input impedance 1 MΩ
    • Programmable Fine Adjust Gain Amplifier: ± 12 dB Gain, 0.5 dB step.
    • 24 bit Digital Audio convertion Bit Depth.
    • TRS noise cancelling;
    • TRS connectors (balanced compatible);
    • Volume Control: 0 to -127 dB, 0.5dB step;
  • Headphone output:
    • 6.35mm TRS connector
    • Digital volume control from +12dB to −33dB
  • SPDIF output:
    • 3.5mm coaxial TS connector (signal on tip port)
Control Voltage
  • 2 CV input ports
    • Switchable to CV Expression (you can use this input to connect one expression pedal)
    • Stereo 6.35mm TRS connector
  • 2 CV output port
Note:
  • On the Duo X Limited edition, both the CV inputs and outputs have a range from 0V to 5V.
  • On the Duo X normal production edition, both the CV inputs and outputs have a range from 0V to 10V.
Important Wrong use of the CV ports may damage the MOD Duo X. Please pay special attention.
  • MIDI IN connector - DIN 5 pins
  • MIDI OUT connector - DIN 5 pins
USB
  • USB Host
    • Connector: Type-A
    • Standard: USB 2.0
  • USB Device
    • Connector: Type-B
    • Standard: USB 2.0
Device Controller
  • 1x 2.8" LCD display
  • 2x endless knobs
  • 3x performance buttons
  • 8x knobs
  • 4x push buttons switches with color LEDs
Software
The MOD DuoX runs the MOD runs latest Operating System. Support for the MOD DuoX was added to the MOD OS on version 1.7.
