Creating Audio Plugins
Revision as of 14:32, 24 October 2021 by FalkTX (talk | contribs)
  • Digital signal processing (DSP)
  • Programming
  • Basic math
Creating plugins
There are 3 ways to create an LV2 plugin:
  • Coding everything from scratch
  • Using a framework or high level language (e.g.: DPF, Faust, JUCE)
  • Using visual programming software (e.g.: MAX Gen~, PureData)
Regardless the option you choose it's highly recommended that you use Linux (preferable) or Mac OS for development. Not only all MOD team developers use Linux but most of the LV2 developers does as well. In other words this means that almost all documentation you will find assumes that you are using Linux and in the case you need to ask for support it'll be much easier.
From scratch
The first option, coding everything from scratch, is the hardest one if you are new to programming. Here we will need to know C or C++ to code the plugins and also read the LV2 documentation and examples. Although the learning curve is steep (seeing that you'll need to learn programming first) that's a good choice if you want full control of what you're doing and probably it's the best choice to write well performing plugins.
What to learn:
  • C/C++ language
  • LV2 standard
To learn about the LV2 standard start reading this [blog post http://harryhaaren.blogspot.com.br/2012/06/writing-lv2-plugins-lv2-overview.html] by Harry Van Haaren.
[Programming LV2 Plugins Book http://lv2plug.in/book/] from David Robillard. It aims to explain the LV2 by using examples instead of API documentation.
LV2 standard
External references
The LV2 GitHub wiki has lots of useful links and references that can help you in the process of creating a LV2 plugin. We highly recommend you to have a look.
Framework / High Level Language
TODO: Juce and DISTRHO Plugin Framework (DPF), Examples: there are plugins done using DPF, need to find out)
TODO: development environment
Visual Programming
TODO: Max/MSP (MAX Gen~) Examples: shiro plugins
TODO: Puredata (Camomile) Examples?
[1]
