Dealing with noise issues
We prepared this short guide to help you troubleshoot some noise issues that you may face using MOD devices.
Gain staging
Often devices, when you can set one or multiple gains, have colourful LEDs or graphic representations. Optimal gain staging headroom is obtained when you play on the yellow area.
When the output of your device is too "hot" (or loud) for the device that you have it plugged into, it's better for the range to turn down on the codec gain (on the settings of your device) than to do it using a plugin in the pedalboard.
Pedalboard setup
Some noise issues are caused by your pedalboard arrangement and the plugins that you are using. Some amplifiers or tape simulators color the signal with their own programmed enhancements and often can be dialed back when necessary. Yet, sometimes developers don't give control to the users on these enhancements.
Ground loop issues
- if the receiving device has balanced inputs, use balanced/stereo cables;
- if none of the above works experiment with a passive DI or ground loop isolator and balanced/stereo cables.
USB connection to a grounded device (for example: a computer)
- try a different USB port;
- try through a USB hub;
- add a USB isolator.
For MOD Dwarf users
