Troubleshooting Windows Connection
Below follows a tutorial on how to install it.
If your system reports the driver as missing, make windows look for drivers and skip to step 4.
2. Find the MOD device. It either appears as 'Duo/Dwarf Ethernet' under 'Unknown devices' or as a USB Serial device.
If you have 'Duo/Dwarf Ethernet' as unknown device, select it.
5. Click the 'Browse' button and select the folder where you extracted the contents of the mod-duo-rndis.zip file, then click 'Next'.
8. If everything is working correctly, the unit will appear as 'USB Ethernet/RNDIS Gadget' under 'Network adapters'
