Developer Images
Revision as of 08:09, 9 September 2021 by FalkTX (talk | contribs)
These include:
Release links
Useful links
Access_MOD_using_SSH Releases#Manual_update
Instructions
Carla
MOD-SDK
[MOD-SDK https://github.com/moddevices/mod-sdk] runs at port 9000, so you can access it using http://192.168.51.1:9000/
Valgrind
systemctl stop jack2
# setting up environment
valgrind jackd -r -t 500 -C /etc/jack-internal-session.conf -d alsa -d hw:0 -r 48000 -p 1024
