Developer Images
These include:
Release links
Instructions
Carla
MOD-SDK
Valgrind
systemctl stop jack2
# setting up environment
valgrind jackd -r -t 500 -C /etc/jack-internal-session.conf -d alsa -d hw:0 -r 48000 -p 1024There will be a few warnings/errors regarding epoll_ctl which comes from ableton link, ignore them.
