Developer Images
Revision as of 08:05, 9 September 2021 by FalkTX (talk | contribs)
These include:
Release links
Instructions
Carla
MOD-SDK
Valgrind
# stopping jack2, run it a few times if jackd complains server already active systemctl stop jack2 # setting up environment source /etc/mod-hardware-descriptor.env export MOD_MIDI_SERIAL_PORT=${MIDI_SERIAL_PORT} export MOD_PEAKMETER_BUS_NUMBER=${I2C_MAIN_BUS} export MOD_PEAKMETER_GPIO_PATH=${PCA9685_OE_GPIO_PATH} # starting jackd with the typical JACK clients valgrind jackd -r -t 500 -C /etc/jack-internal-session.conf -d alsa -d hw:0 -r 48000 -p 1024
  1. Turn on your MOD
  9. Copy the tar file onto the new drive and use your OS option to safely remove the drive
