Dealing with noise issues
We prepared this short guide to help you troubleshoot some noise issues that you may face using MOD devices.
Gain staging
Pedalboard setup
Ground loop issues
Ground loops are some of the most common issues causing noise on audio devices. It results often in a modulated hum around 50 and 60Hz. You can read more about them here.
- if the receiving device has balanced inputs, use balanced/stereo cables;
- if none of the above works experiment with a passive DI or ground loop isolator and balanced/stereo cables.
USB connection to a grounded device (for example: a computer)
- try a different USB port;
- try through a USB hub;
- add a USB isolator.
For MOD Dwarf users
