Dealing with noise issues
It is common nowadays in modern music setups to have noise issues that require some thought and experience to sort out. Especially when you are using devices like computers these issues happen often since these devices are required in many countries by law to have grounded power supplies. As our devices are in practice small computers with CPU, RAM, etc. they are required to use grounded power supplies. As a consequence, some users may face common noise issues with this type of device.
Gain staging
Pedalboard setup
Ground loop issues
Ground loops are some of the most common issues causing noise on audio devices. It results often in a modulated hum around 50 and 60Hz. You can read more about them here.
- if the receiving device has balanced inputs, use balanced cables;
- if none of the above works experiment with a passive DI or ground loop isolator and balanced cables.
USB connection to a grounded device (for example: a computer)
- try a different USB port;
- try through a USB hub;
- add a USB isolator.
For MOD Dwarf users
