Plugin Criteria
Jump to navigation
Jump to search
- has a modgui
- has a valid version
- homepage must be valid
- plugin comment with copyright attribution when needed (todo give example)
- use 0-100 (percentage) instead of 0-1 range where it makes sense
Recommended but not absolutely required:
- modgui is nicely draggable
- on and off audible volume should be consistent, unless obviously not the case (ie, has a gain parameter)
- short but descriptive parameter names
- parameter names in "Title" form (first case letter uppercase, rest lowercase)
- parameter name on modgui should match name on settings
Nice to have but not required in any way
