Plugin Criteria
Jump to navigation
Jump to search
- has a modgui
- has a valid version
- homepage must be valid
Recommended but not absolutely required:
- modgui is nicely draggable
- on and off audible volume should be consistent, unless obviously not the case (ie, has a gain parameter)
- short but descriptive parameter names
- parameter names in "Title" form (first case letter uppercase, rest lowercase)
Nice to have but not required in any way
