Plugin Criteria
Jump to navigation
Jump to search
- has a modgui
- has a valid version
Recommended but not absolutely required:
- if plugin uses real values (that is, not normalized), use units to indicate their meaning
- modgui is nicely draggable
Nice to have but not required in any way
