Duo X Technical Specs
Revision as of 15:14, 4 May 2021 by Joao.sensiguitar (talk | contribs)
Technical specs
- length: 188 mm
- width: 163 mm
- height: 63 mm
Processors
- RockChip RK3399 CPU:
- CPU family: ARM A72 + A53
- Platform bit depth: 64 bit
- Memory: 2 GB RAM
- Flash Storage: 16 GB
Audio
- TS connectors;
- Input impedance 1 MΩ
- TRS noise cancelling;
- Headphone output:
- 6.35mm TRS connector
- SPDIF output:
- 3.5mm coaxial TS connector
Control Voltage
- 2 CV input ports
- Togglable to CV Expression (you can use this input to connect one expression pedal)
- Stereo 6.35mm TRS connector
- 2 CV output port
Note:
- On the Duo X Limited edition, both the CV inputs and outputs have a range from 0V to 5V.
- On the Duo X normal production edition, both the CV inputs and outputs have a range from 0V to 10V.
USB
- USB Host
- Connector: Type-A
- Standard: USB 2.0
- USB Device
- Connector: Type-B
- Standard: USB 2.0
Device Controller
- 1x 2.8" LCD display
- 2x endless knobs
- 3x performance buttons
- 8x knobs
- 4x push buttons switches with color LEDs
Software
The MOD DuoX runs the MOD runs latest Operating System. Support for the MOD DuoX was added to the MOD OS on version 1.7.
