Dwarf User Guide
The MOD Dwarf when powered up
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
  • To prevent risk of electric shock and fire because of overheating, please ensure that curtains and other objects do not prevent adapter ventilation.
USB Host port (USB port A)
Menu button
Footswicth A
Footswicthes B and C
Accessing Tool
Accessing Pedalboards
Display
  • width: 202 mm
  • length: 105 mm
  • height: 54 mm
  • Off: below -40dB
  • Red: between -1dB and 0dB
Dwarf gain staging
WIP--------
(add image of tuner)
(image of banks screen)
The MOD Dwarf allows you to switch between 8 pages and 3 subpages. This means that each of you the 3 endless knobs on your Dwarf can be assigned up to 24 parameters. The footswitches A and B can be assigned up to 8 parameters each.
