Revision as of 13:34, 23 February 2021 by FalkTX (talk | contribs) (→‎v1.10.0-RC1)
Stable Releases
Duo X: modduox-v1.7.4.855.tar
  1. Turn on your MOD
  • NEW: MOD Dwarf support
  • LV2 control-input-port-change-request extension support
  • CC value set
  • fix frame reset to 0
  • general fixing to addressing dialog
  • never cache plugin-related information for local plugin builds
  • rework controller protocol messages, in preparation for more complex types used for the Dwarf
  • rework preset loading and transport change behaviour, more robust now
  • buildEnvironment tag in store (none aka "prod", "dev", "local" and "labs")
  • Minor cleanup of settings.html, tiny bit more responsive
  • Don't show broken pedalboards in banks, have fallback pedalboard
  • Fix window title for several save dialogs
  • Remove old hacky behaviour for cpu 100% on xrun
  • Set pedalboardModified flag when a param changes or plugin moves
  • When plugin is moved in UI, new position is broadcast to all open sessions
  • Safer use of save and reset through HMI
  • Fix pedalboard snapshots text highlight, close rename with esc
  • Take some precautions against corrupt data when saving screenshot
  • Improve quick loading of bank pedalboards
  • new device screen layout
  • new font
  • make bank-config only set at the very end
  • increase number of parameter pages from 3 to 6
  • 2 button page mode
  • fix sporadic boot issues
  • fix disabling snapshots
  • minor UI fixes
  • small cosmetic fixes
  • NEW: Actuator groups
  • Support for new Duo X unit
  • MIDI Clock slave and output
  • Unlocked parameters
  • User profiles
  • Fixed small all around bugs
  • Renaming unstable -> beta
  • Settings button
  • Minors
  • NEW: Global Tempo
  • NEW: Settings Panel
  • Add zita-njbridge package
  • fix audio inputs DC offset
  • Control Chain support
  • tuner added to 2nd display
  • several optimizations
  • Sort plugins ignoring case
  • Fix missing favicon images
  • add auto-upgrade system
  • Fix save dialog auto-focus
  • fix inverted DAC controls
  • implemented leds peak-meter
  • removed disconnect button
  • fix boot issues
  • Initial Version
