- 3 Release 1.10
- 4 Release 1.9
- 5 Release 1.8
- 6 Release 1.7
- 7 Release 1.6
- 8 Release 1.5
- 9 Release 1.4
- 10 Release 1.3
- 11 Release 1.2
- 12 Release 1.1
- 13 Release 1.0
- 14 Release 0.15.0
- 15 Release 0.14.0
- 16 Release 0.13.0
- 17 Release 0.12.2
- 18 Release 0.11.3
- 19 Release 0.10.4
- 20 Release 0.9.0
- LV2 parameter extension (boolean, integer, long, float, double, URI and vector)
- LV2 patch extension (get and set)
- LV2 control-input-port-change-request extension
- CC value set
- fix frame reset to 0
- general fixing to addressing dialog
- never cache plugin-related information for local plugin builds
- rework controller protocol messages, in preparation for more complex types used for the Dwarf
- rework preset loading and transport change behaviour, more robust now
- buildEnvironment tag in store (none aka "prod", "dev", "local" and "labs")
- Minor cleanup of settings.html, tiny bit more responsive
- Don't show broken pedalboards in banks, have fallback pedalboard
- Fix window title for several save dialogs
- Remove old hacky behaviour for cpu 100% on xrun
- Set pedalboardModified flag when a param changes or plugin moves
- When plugin is moved in UI, new position is broadcast to all open sessions
- Safer use of save and reset through HMI
- Fix pedalboard snapshots text highlight, close rename with esc
- Take some precautions against corrupt data when saving screenshot
- Improve quick loading of bank pedalboards
- new device screen layout
- new font
- make bank-config only set at the very end
- increase number of parameter pages from 3 to 6
- 2 button page mode
- fix sporadic boot issues
