- 3 Release 1.10
- 4 Release 1.9
- 5 Release 1.8
- 6 Release 1.7
- 7 Release 1.6
- 8 Release 1.5
- 9 Release 1.4
- 10 Release 1.3
- 11 Release 1.2
- 12 Release 1.1
- 13 Release 1.0
- 14 Release 0.15.0
- 15 Release 0.14.0
- 16 Release 0.13.0
- 17 Release 0.12.2
- 18 Release 0.11.3
- 19 Release 0.10.4
- 20 Release 0.9.0
- LV2 parameter extension (boolean, integer, long, float, double, URI and vector)
- LV2 patch extension (get and set)
- LV2 control-input-port-change-request extension
- Special rawMIDIClockAcess port property support
- CC value set
- fix frame reset to 0
- general fixing to addressing dialog
- never cache plugin-related information for local plugin builds
- rework controller protocol messages, in preparation for more complex types used for the Dwarf
- rework preset loading and transport change behaviour, more robust now
- buildEnvironment tag in store (none aka "prod", "dev", "local" and "labs")
- Minor cleanup of settings.html, tiny bit more responsive
- Don't show broken pedalboards in banks, have fallback pedalboard
Add non-installed plugin store filter Fix window title for several save dialogs Remove old hacky behaviour for cpu 100% on xrun Set pedalboardModified flag when a param changes or plugin moves When plugin is moved in UI, new position is broadcast to all open sessions Safer use of save and reset through HMI Fix pedalboard snapshots text highlight, close rename with esc Take some precautions against corrupt data when saving screenshot Improve quick loading of bank pedalboards
- new device screen layout
- new font
- make bank-config only set at the very end
- increase number of parameter pages from 3 to 6
- 2 button page mode
- fix sporadic boot issues
