Revision as of 12:34, 23 February 2021 by FalkTX (talk | contribs) (→‎v1.10.0-RC1)
Stable Releases
Duo X: modduox-v1.7.4.855.tar
  1. Turn on your MOD
  • NEW: MOD Dwarf support
  • LV2 parameter extension (boolean, integer, long, float, double, URI and vector)
  • LV2 patch extension (get and set)
  • LV2 control-input-port-change-request extension
  • Special rawMIDIClockAcess port property support
  • CC value set
  • fix frame reset to 0
  • general fixing to addressing dialog
  • never cache plugin-related information for local plugin builds
  • rework controller protocol messages, in preparation for more complex types used for the Dwarf
  • rework preset loading and transport change behaviour, more robust now
  • buildEnvironment tag in store (none aka "prod", "dev", "local" and "labs")
  • Minor cleanup of settings.html, tiny bit more responsive
  • Don't show broken pedalboards in banks, have fallback pedalboard
Add non-installed plugin store filter Fix window title for several save dialogs Remove old hacky behaviour for cpu 100% on xrun Set pedalboardModified flag when a param changes or plugin moves When plugin is moved in UI, new position is broadcast to all open sessions Safer use of save and reset through HMI Fix pedalboard snapshots text highlight, close rename with esc Take some precautions against corrupt data when saving screenshot Improve quick loading of bank pedalboards
  • new device screen layout
  • new font
  • make bank-config only set at the very end
  • increase number of parameter pages from 3 to 6
  • 2 button page mode
  • fix disabling snapshots
  • minor UI fixes
  • small cosmetic fixes
  • NEW: Actuator groups
  • Support for new Duo X unit
  • MIDI Clock slave and output
  • Unlocked parameters
  • User profiles
  • Fixed small all around bugs
  • Renaming unstable -> beta
  • Settings button
  • Minors
  • NEW: Global Tempo
  • NEW: Settings Panel
  • Add zita-njbridge package
  • fix audio inputs DC offset
  • Control Chain support
  • tuner added to 2nd display
  • several optimizations
  • Sort plugins ignoring case
  • Fix missing favicon images
  • add auto-upgrade system
  • Fix save dialog auto-focus
  • fix inverted DAC controls
  • implemented leds peak-meter
  • removed disconnect button
  • fix boot issues
  • Initial Version
