Dwarf User Guide
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
- To ensure adequate ventilation, do not place
the power adapter in tight spaces.
- To prevent risk of electric shock and fire because of overheating, please ensure that curtains and other objects do not prevent adapter ventilation.
USB Host port (USB port A)
Menu button
Footswicth A
Footswicthes B and C
Accessing Tool
Accessing Pedalboards
Display
- width: 202 mm
- length: 105 mm
- height: 54 mm
Dwarf gain staging
WIP--------
- 1st page: red
- 2nd page: yellow
- 3rd page: green
