Dwarf User Guide
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
USB Host port (USB port A)
Menu button
Footswicth A
Footswicthes B and C
Accessing Tool
Accessing Pedalboards
Display
- width: 202 mm
- length: 105 mm
- height: 54 mm
- 1st page: red
- 2nd page: yellow
- 3rd page: green
