Audio Through USB
Using netJACK2
sudo ufw allow 19000Then, ssh into the Duo, and run:
touch /data/enable-netmanager
systemctl start jack-netmanagerNOTE: You only need to run this command once. The next the Duo boots, jack-netmanager will be loaded by default. Delete the /data/enable-netmanager file inside the Duo to remove this auto-start feature.
jackd -R -P 80 -d net -a 192.168.51.1 -C 2 -P 2 -i 1 -o 1 -l 4 -n mod-slave -sAdjust the parameters as needed, but keep mod-slave as the client name.
Parameters explained
| -a | Multicast address, in this case the IP address of the MOD Duo. |
| -C | Number of audio input ports on the slave. This determines the number of audio output ports on the MOD Duo, marked as "Hardware Audio To Slave" ports in the web interface. |
| -P | Number of audio output ports on the slave. This determines the number of audio input ports on the MOD Duo, marked as "Hardware Audio From Slave" ports in the web interface. |
| -i | Number of MIDI input ports on the slave. This determines the number of MIDI output ports on the MOD Duo, marked as "Hardware Midi To Slave" ports in the web interface. |
| -o | Number of MIDI output ports on the slave. This determines the number of MIDI input ports on the MOD Duo, marked as "Hardware Midi From Slave" ports in the web interface. |
jack_control dps latency 4
jack_control startUsing USB Audio Gadget
NOTE: This requires v1.10 or later.
NOTE: This is EXPERIMENTAL and doesn't work on Windows right now.
touch /data/enable-usb-multi-gadget
touch /data/enable-usb-audio-gadget
# if using windows, also run:
touch /data/enable-usb-windows-compatNow we reboot
sync && hmi-reset && rebootSome caveats and known issues:
- De-sync of USB packets will pause the audio (either capture or playback) for 10 seconds
- Not supported on Windows right now, to be dealt with later on
- MOD Duo works 100%
- MOD Duo X "production units" work well most of the time, with occasional playback sync issues
- MOD Dwarf has issues with playback, but capture works well
