Audio Through USB
Using netJACK2
sudo ufw allow 19000Then, ssh into the Duo, and run:
touch /data/enable-netmanager
systemctl start jack-netmanagerNOTE: You only need to run this command once. The next the Duo boots, jack-netmanager will be loaded by default. Delete the /data/enable-netmanager file inside the Duo to remove this auto-start feature.
jackd -R -P 80 -d net -a 192.168.51.1 -C 2 -P 2 -i 1 -o 1 -l 4 -n mod-slave -sAdjust the parameters as needed, but keep mod-slave as the client name.
Parameters explained
| -a | Multicast address, in this case the IP address of the MOD Duo. |
| -C | Number of audio input ports on the slave. This determines the number of audio output ports on the MOD Duo, marked as "Hardware Audio To Slave" ports in the web interface. |
| -P | Number of audio output ports on the slave. This determines the number of audio input ports on the MOD Duo, marked as "Hardware Audio From Slave" ports in the web interface. |
| -i | Number of MIDI input ports on the slave. This determines the number of MIDI output ports on the MOD Duo, marked as "Hardware Midi To Slave" ports in the web interface. |
| -o | Number of MIDI output ports on the slave. This determines the number of MIDI input ports on the MOD Duo, marked as "Hardware Midi From Slave" ports in the web interface. |
jack_control dps latency 4
jack_control startUsing USB Audio Gadget
NOTE: This requires v1.10 or later.
NOTE: This is EXPERIMENTAL and doesn't work on Windows right now.
We are going to enable USB Audio Gadget through UAC2 by replacing some system files and activating the unit gadget mode.
touch /data/enable-usb-multi-gadget
mount / -o remount,rwSecond, open /sbin/enable-usb-gadget.sh inside the unit (with either nano or vi, as you prefer) and replace its entire contents with:
#!/bin/bash
# If we need to wait for usb to be plugged in before activating gadget mode, do nothing
# On such units, we can only register g_ether after the USB is plugged in
if [ "${USB_PLUGGED_IN_WAIT_REQUITED}" -eq 1 ] && [ -n "${STARTED_VIA_SYSTEMD}" ]; then
exit 0
fi
if [ -f /data/enable-usb-multi-gadget ] && [ -e /proc/device-tree/compatible ]; then
/sbin/modprobe libcomposite
if [ -f /data/enable-usb-windows-compat ]; then
/sbin/modprobe usb_f_rndis
WINDOWS_COMPAT_MODE=1
else
WINDOWS_COMPAT_MODE=0
fi
# Read serial
if [ -f /var/cache/mod/tag ]; then
SERIAL=$(cat /var/cache/mod/tag)
else
SERIAL=$(mod-hardware tag)
fi
SERIAL=$(echo ${SERIAL} | awk 'sub("-","\n")' | tail -n 1 | sed 's/-//g')
# Create MAC address suffix
MAC=$(echo ${SERIAL} | tail -c 10 | sed 's/\(\w\w\)/:\1/g')
# create new composite gadget instance
mkdir /sys/kernel/config/usb_gadget/multi
cd /sys/kernel/config/usb_gadget/multi
# assign an unique id based on model, so each one is handled separately/differently by the host OS
if [ "${PLATFORM}" = "duo" ]; then
PRODUCT_CODE="1"
elif [ "${PLATFORM}" = "dwarf" ]; then
PRODUCT_CODE="2"
elif [ -n "${MODEL_IMX8MQ}" ] && [ "${MODEL_IMX8MQ}" -eq 1 ]; then
PRODUCT_CODE="3"
else
PRODUCT_CODE="4"
fi
# please increment this value everytime you make changes here!
PRODUCT_VERSION="1"
# make a unique device id based on previous values
echo "0x3${PRODUCT_CODE}${PRODUCT_VERSION}${WINDOWS_COMPAT_MODE}" > bcdDevice
# USB ID, see more at http://www.linux-usb.org/usb.ids
echo "0x1d6b" > idVendor
echo "0x0104" > idProduct
# Setup USB Gadget
echo 0x0200 > bcdUSB # USB 2.0
echo 0xEF > bDeviceClass # Miscellaneous
echo 0x02 > bDeviceSubClass
echo 0x01 > bDeviceProtocol
# USB Information (0x409 is English)
mkdir strings/0x409
echo "MOD Devices" > strings/0x409/manufacturer
echo "${MODEL_NAME}" > strings/0x409/product
echo "${SERIAL}" > strings/0x409/serialnumber
# Setup MIDI
mkdir functions/midi.usb0
if [ ${WINDOWS_COMPAT_MODE} -eq 1 ]; then
# Setup RNDIS
mkdir functions/rndis.usb0
echo "22${MAC}" > functions/rndis.usb0/dev_addr
echo "32${MAC}" > functions/rndis.usb0/host_addr
echo "RNDIS" > functions/rndis.usb0/os_desc/interface.rndis/compatible_id
echo "5162001" > functions/rndis.usb0/os_desc/interface.rndis/sub_compatible_id
## Hacky stuff for Windows
echo "1" > os_desc/use
echo "0xcd" > os_desc/b_vendor_code
echo "MSFT100" > os_desc/qw_sign
else
# Setup ECM
mkdir functions/ecm.usb0
echo "02${MAC}" > functions/ecm.usb0/dev_addr
echo "12${MAC}" > functions/ecm.usb0/host_addr
# Setup UAC2
mkdir functions/uac2.usb0
echo "3" > functions/uac2.usb0/c_chmask
echo "3" > functions/uac2.usb0/c_ssize
echo "48000" > functions/uac2.usb0/c_srate
echo "3" > functions/uac2.usb0/p_chmask
echo "3" > functions/uac2.usb0/p_ssize
echo "48000" > functions/uac2.usb0/p_srate
fi
# Configuration
mkdir configs/mod.1
echo "0xc0" > configs/mod.1/bmAttributes # self-powerered
echo "1" > configs/mod.1/MaxPower # 2mA
mkdir configs/mod.1/strings/0x409
echo "${MODEL_NAME}" > configs/mod.1/strings/0x409/configuration
ln -s functions/rndis.usb0 configs/mod.1
ln -s configs/mod.1 os_desc
else
ln -s functions/ecm.usb0 configs/mod.1
ln -s functions/uac2.usb0 configs/mod.1
fi
ln -s functions/midi.usb0 configs/mod.1
# Ready to roll!
/bin/find /sys/class/udc -type l -maxdepth 1 | /bin/tail -n 1 | /bin/awk 'sub("/sys/class/udc/","")' > UDC
else
/sbin/modprobe g_ether
fi
# Setup IRQ priority, taken from `set-irq-priorities.sh`
if [ -n "${USB_IRQ}" ]; then
USB_PID=$(/usr/bin/ps -e | /usr/bin/grep irq/${USB_IRQ} | /usr/bin/awk '{print $1}')
# USB IRQ is sometimes only active if a usb host or gadget is plugged in
if [ -n "${USB_PID}" ]; then
# we can have 2 processes handling usb
if [ "$(/usr/bin/echo ${USB_PID} | /usr/bin/wc -w)" -eq 2 ]; then
USB_PIDS=($(/usr/bin/echo ${USB_PID}))
/usr/bin/chrt -f -p 55 ${USB_PIDS[0]}
/usr/bin/chrt -f -p 55 ${USB_PIDS[1]}
else
/usr/bin/chrt -f -p 55 ${USB_PID}
fi
fi
fi
# Bring up usb0 ethernet interface
/sbin/ifup usb0
# Restarts sshd service, needed after usb0 being active
/usr/bin/systemctl restart sshd
# On legacy units, g_ether waits for first USB to be plugged in
# As such, netmanager cannot start on boot, so do that now
if [ -f /data/enable-netmanager ] && [ "${USB_PLUGGED_IN_WAIT_REQUITED}" -eq 1 ]; then
/usr/bin/systemctl start jack-netmanager
fi
exit 0Now we reboot
hmi-reset
sync
reboot
