Revision as of 16:25, 27 November 2020 by FalkTX (talk | contribs)
Stable Releases
1.9 2020/09/23 CV addressings; CV hardware support; Smooth peakmeters; Duo X potentiometer calibration; UI/UX improvements; Duo mainline Duo: modduo-v1.9.2.1605.tar
Duo X: modduox-v1.9.2.1604.tar
Duo X: modduox-v1.7.4.855.tar
  1. Turn on your MOD
Released on 2020/12/01
WIP
  • Fix audio host crash when loading certain plugins on Duo X production units
  • Fix headphone "pop" during boot (Duo X production units only)
  • Fix support for a few Duo nand units with mainline kernel
  • fix disabling snapshots
  • minor UI fixes
  • small cosmetic fixes
  • NEW: Actuator groups
  • Support for new Duo X unit
  • MIDI Clock slave and output
  • Unlocked parameters
  • User profiles
  • Fixed small all around bugs
  • Renaming unstable -> beta
  • Settings button
  • Minors
  • NEW: Global Tempo
  • NEW: Settings Panel
  • Add zita-njbridge package
  • fix audio inputs DC offset
  • Control Chain support
  • tuner added to 2nd display
  • several optimizations
  • Sort plugins ignoring case
  • Fix missing favicon images
  • add auto-upgrade system
  • Fix save dialog auto-focus
  • fix inverted DAC controls
  • implemented leds peak-meter
  • removed disconnect button
  • fix boot issues
  • Initial Version
