Duo X Technical Specs
Technical specs
MOD Duo X dimensions in mm
- length: 188 mm
- width: 163 mm
- height: 63 mm
Processors
- RockChip RK3399 CPU:
- CPU family: ARM A72 + A53
- Platform bit depth: 64 bit
- Memory: 2 GB RAM
- Flash Storage: 16 GB
Audio
- TS connectors;
- Input impedance 1 MΩ
- TRS noise cancelling;
- Headphone output:
- 6.35mm TRS connector
- SPDIF output:
- 3.5mm coaxial TS connector
Control Voltage
- 2 CV input ports
- Togglable to CV Expression (you can use this input to connect one expression pedal)
- Stereo 6.35mm TRS connector
- 2 CV output port
USB
- USB Bluetooth
- USB Wifi
- USB MIDI
- USB Ethernet Connection
- USB Mass Storage (used for updates)
Controllers
- 2 endless knobs
- 3 performance buttons (that allow you to switch between control assignments pages or save snapshots)
- 8 knobs
- 4 push buttons switches with color LEDs
Plugin Control
- 2x endless knobs
- 3 parameters can be assigned to each of the endless knobs
- 8x knobs
- 3 parameters can be assigned to each knob
- 4x pushbuttons
- 3 parameters can be assigned to each pushbutton
Peripherals
Software
The MOD Duo X uses a Linux operating system with LV2 plugins to define virtual pedalboards.
