New FAQ
- 1 General Device Questions
- 1.1 What are the differences between the MOD Duo and the MOD Duo X?
- 1.2 Can I control MIDI synths with a guitar?
- 1.3 Can be powered with a battery?
- 1.4 Does it support MPE?
- 1.5 Can I use it as an FX loop?
- 1.6 Do I need a computer or other similar device to play with the devices?
- 1.7 Do I need to be connected to the internet to use the MOD devices?
- 1.8 How are the MOD devices updated?
- 2 MOD Duo
- 3 MOD Duo X
- 4 MOD Dwarf
- 5 Plugins
- 6 MOD Peripherals
- 7 Audio
- 8 MIDI
- 9 Control Voltage
- 10 Control Chain
In generic terms, the MOD Duo is designed to be a floor unit especially focused to be used by guitar and bass players. The MOD Duo X takes the same technology, focusing mostly on the synthesizers and live interaction with effects - the reason that justifies the bigger number of actuators. If we take a closer look at the technical aspects of both devices, the Duo X is a more powerful unit. With a more powerful processor, bigger memory, storage, and bit rate, the Duo X allow you to run more complex pedalboards with multiple instances of high requirements plugins. The Duo X also has physical CV input and output ports, which allows it to interact with modular synths, for example. The Duo X has also an extra input where the user can connect an expression pedal.
No, MOD devices can't be powered with batteries. Each of the devices comes with a specific power supply that fits the particular power needs of each of the devices. We recommend using the official power supply, as it keeps the noise level low. Using a power supply with identical specifications is possible, though not supported by us. For more info on this please check this chapter on our wiki.
Yes. MOD devices are extremely versatile effect units. As you can totally program and arrange the effects inside the device you can set the device in pretty much any position of your setup.
No. You can create pedalboards using the plugins that are already installed on your MOD device. Internet connection is required only to install new plug-ins, to share or download other users’ pedalboards and for device updates.
The MOD devices check if they are updated every time you connect to the graphical interface. If there is an update available, you will be notified. You can then perform the update with a single click. Note that the device where you are visualising the graphical interface must be connected to the internet. Our team of programmers and engineers work to develop new features and to improve existing ones. We launch regular updates, which means that your MOD device constantly becomes more efficient and more stable.
MOD Duo
Do I need an amp to use the Duo?
Not necessarily, but you are free to use it if you wish. As you have amp simulators available on MOD platform, you can load them on your pedalboards inside your MOD Duo and connect it directly to a mixer or any sound system. Yet, you can also connect your MOD Duo to an amp and use it as your sound source. If you choose to use it this way, as a best practice we suggest that you don't use amp simulators inside your MOD Duo. But as music-making is all about creativity and experimenting, you are free to load them on your pedalboards anyway. This will not break your device. Be only aware of the output volumes of you MOD Duo.
MOD Duo X
MOD Dwarf
Plugins
Are the effects that run in the MOD devices made only by MOD company?
Does the MOD Duo run VST effects?
No. The format used by the MOD Duo is LV2, which is similar to VST, but released under an open-source license, avoiding the license hassles related to VST and allowing multiple developers around the world to create effects for the MOD Duo.
Are plugins free of charge?
Not all plugins are free. Yet, most plugins on MOD Plugin Store are indeed free of charge. We currently have close to 1000 plug-ins in our library and new plug-ins are regularly added. The payed plug-ins allow developers from around the world to sell their creations, encouraging these programmers to spend more time developing new and unusual plug-ins.
Can I install plugins on the MOD Duo that are not available on the MOD cloud?
Yes. MOD gives full support to the LV2 standard and any working LV2 plugin will work in the MOD Duo. Installation is done using our free SDK.
MOD Peripherals
Audio
Can the MOD devices be used to control other devices via MIDI?
Yes. You have plugins available on MOD platform that allow you to send MIDI data to other devices using both the old school MIDI output or USB MIDI, both available on the devices. You can for example set a parallel MIDI "command line" together with your effects/instruments chain or you can both of them interact. As the platform allows you to arrange and connect plugins (no matter if effects, generators, MIDI, etc.) as you wish, your possibilities are pretty much infinite.
Do the MOD devices support MIDI?
Yes, all MOD devices have great MIDI-connectivity. There is support for old-school MIDI over DIN-cables, as well as USB-MIDI over USB-cables. It is even possible to add a USB hub to the devices to expand the number of USB connections that you can make.
