MOD Duo User Guide
Headphone jack
This port is mostly used to connect the MOD Duo to your PC for setting it up. When executing a manual system update, this port turns the MOD Duo into a mass-storage device, so that you can copy the update-file to the MOD Duo.
General knob actions
Left knob actions
Right knob actions
General footswitch actions
- width: 180 mm
- length: 160 mm
- height: 74.7 mm
- Off: below -30dB
- Red: above -3dB
After you have powered on and adjusted the volumes of your MOD Duo, it is ready for playtime. The MOD Duo comes with many pedalboards ready to be used. They are organized in banks and can be accessed via SETTINGS menu.
Hooking up the MOD Duo
Wiring examples
Guitar
- semi-accoustic setup
Vocals
- MIC -> MOD -> DI -> PA
Keys
- HW Synth -> MOD
- ePiano -> MOD
- keyboard -> MOD
- MIDI Grid-controller -> MOD
Exotic
TODO: Add exotic use cases
- Chapman stick
- Wind instruments
- Accoustic instruments
