In this page you find instructions to connect your computer to the MOD device using Bluetooth.
Please note that the MOD devices do not include a Bluetooth chip inside, you have to plug a Bluetooth USB dongle on them for this to work.
Bluetooth options
The controller has a menu option dedicated to Bluetooth. To access this menu please click and hold the left knob and scroll down to the "Settings" menu
- Unsupported - the Bluetooth version of the dongle in use is too old (needs >= Bluetooth 3)
You can customize this name by creating a file named '/data/bluetooth/name' inside your MOD device. Its contents define the name.
Connecting using Bluetooth
In all cases, plug you Bluetooth dongle before turning the MOD device on.
Windows
3. Open the settings menu of your MOD device (by holding the left knob down), go to the Bluetooth menu and enable discovery.
5. Select your MOD device from the list and click 'Next'.
7. Select your MOD device icon and click 'Connect using' then 'Access point'
Mac OS
1. Turn on your MOD device and plug a Bluetooth USB dongle into it
3. Select your MOD device and click 'Continue'
5. After the setup finishes, connect to the MOD device Bluetooth network
2. Wait for it to boot
3. Open your MOD device settings menu (by holding the left knob down), go to the Bluetooth menu and enable discovery
4. Use your Bluetooth manager application to look for Bluetooth devices
5. Select your MOD device and connect to it
6. Join the Bluetooth network created by your MOD device
