Note: On MOD Duo (Not MOD Duo X) You can quickly access the Tuner by pressing and holding the right endless knob any time. Press and hold it again to exit. On the MOD Duo X you can only access the tuner via the Settings menu.
  • Inputs
  • Outputs
  • Sync & MIDI
  • Bluetooth
  • Info
  • System Upgrade
Stereo Link: If on, input gains for both channels will be linked and changes applied to one channel will also be applied to the other one.
CV / HP Output (Duo X): Select if this output port works either as an headphones or CV output.
PEDALBOARD NAV MIDI CHN
SHAPSHOT NAV MIDI CHAN
TODO
  • 0% (off)
  • 25%
  • 50%
  • 75%
  • 100%
