WiFi
Step 0: Connect MOD unit via USB
We need to setup a few things on the unit, so it must be connected over USB first so we can SSH into it.
Step 1: Enabling custom firmware
Download any custom firmware that might be needed for your USB device.
The linux-firmware repo https://git.kernel.org/?p=linux/kernel/git/firmware/linux-firmware.git is a good starting point.
Then, create /data/firmware directory, and copy the firmware files inside. Something like...
ssh root@192.168.51.1 "mkdir /data/firmware"
scp rt2870.bin root@192.168.51.1:/data/firmware/
The SSH password is "mod"
Step 2: Create WPA config
Create the file /data/wpa_supplicant.conf with the following contents: (adjust as needed for your network)
update_config=1
network={
        ssid="MyWiFiSSID"
        psk="password-goes-here"
Useful resources:
  1. https://wiki.archlinux.org/index.php/Wpa_supplicant
  2. https://wiki.archlinux.org/index.php/Network_configuration/Wireless#iw
Step 3: Enjoy
That's it!
You can now (re)plug your WiFi USB dongle, and changes should apply automatically.
