Troubleshooting Reinstall
Revision as of 13:21, 24 April 2020 by FalkTX (talk | contribs)
MOD boots the main system, but screens do not work
If the MOD is able to boot (verified by still providing USB Ethernet device) but the screens do not seem to work properly, we can try to re-flash the "top-board"/screen controller unit.
This is fixable through SSH, you simply connect to 192.168.51.1 (user 'root' and password 'mod') and then run the following command:
hmi-update /usr/share/mod/controller/mod*controller.bin
MOD does not boot
If your unit seems unable to boot properly, we can force the unit to start in restore mode.
  1. Turn off your MOD
  2. Hold the left knob and footswitch down (on the Duo X use the left endless-knob and the 1st button from the bottom-left)
  8. Disconnect the USB cable
MOD boots into recovery mode automatically
If this happens, we need to reinstall the latest release, which will allow the unit to boot normally again.
  4. Disconnect the USB cable
MOD does not boot at all, not even in restore mode
This part of the troubleshooting section does not apply to the MOD Duo X, as it does not have a FEL button and thus cannot be forced to boot custom payloads.
See Troubleshooting_Reinstall_Duo for how to reinstall the MOD OS in the Duo.
