| 1.8 | 2019/10/01 | Actuator groups; MIDI separated mode; Tempo divider addressings; Actuator lists pagination | Duo: modduo-v1.8.0.923-RC5.tar
Duo X: modduox-v1.8.0.924-RC5.tar |
