1.8 | 2019/09/28 | Actuator groups; MIDI separated mode; Tempo divider addressings; Actuator lists pagination | Duo: modduo-v1.8.0.910-RC4.tar
Duo X: modduox-v1.8.0.911-RC4.tar |
