| 1.8 | 2019/09/24 | Actuator groups; MIDI separated mode; Tempo divider addressings; Actuator lists pagination | Duo: modduo-v1.8.0.882-RC3.tar
Duo X: modduox-v1.8.0.883-RC3.tar |
Released on 2019/09/27
- fix banks index when changing to a different one in the controller, leading to the wrong pedalboard being loaded
- fix "send MIDI clock" option not being saved in the profiles
