| 1.8 | 2019/09/24 | Actuator groups; MIDI separated mode; Tempo divider addressings; Actuator lists pagination | Duo: modduo-v1.8.0.880-RC3.tar
Duo X: modduox-v1.8.0.881-RC3.tar |
