Using buildroot
This page describes how to make a plugin package for mod-plugin-builder (or MPB for short) using buildroot.
We have a few plugin examples available here.
Plugin package example
PLUGINPKG_VERSION = 1.0.0
$(eval $(cmake-package))
We're using PLUGINPKG as a generic name, you must use your package name in uppercase here.
Alternatives to retrieve source code (DOES THIS SECTION FITS IN HERE??)
The '.mk' file will define how your source code is retrieved.
In most of the existing packages the '.mk' file tells buildroot to download the source. You can use a local tarball or point directly to the source code if you wish.
Just replace the top section with the following:
<PACKAGE_NAME>_SITE = /path/to/source
Make sure to remove the <PACKAGE_NAME>_SOURCE line, if it exists.
If you try changing the eg-amp-lv2 example don't forget to remove the trailing path from the make command. It should look like this:
<PACKAGE_NAME>_TARGET_MAKE = $(TARGET_MAKE_ENV) $(TARGET_CONFIGURE_OPTS) $(MAKE) -C $(@D)
If you place the source code in same folder as the '.mk' file you can set the <PACKAGE_NAME>_SITE like this:
<PACKAGE_NAME>_SITE = $($(PKG)_PKGDIR)/
You can find a working example of such setup here.
Point to a local tarball
If you make a tar.gz file and put it in the same folder as the '.mk' file, you can replace the top section with the following:
<PACKAGE_NAME>_VERSION = 1.0
<PACKAGE_NAME>_SOURCE = eg-amp-1.0.tar.gz
If you want to use an arbitrary path just replace the <PACKAGE_NAME>_SITE variable.
Version and download location
If you rather use a git repository, use something like this:
PLUGINPKG_SITE_METHOD = git
LV2 bundles
Use a space to separate the bundle names. Newline escaping is not supported, everything must be in the same line.
PLUGINPKG_BUNDLES = mybundle1.lv2 mybundle2.lv2
Build rules
If you're using autotools or cmake, buildroot has this covered for you already.
autotools
For autotools, use:
$(eval $(autotools-package))
cmake
For cmake, use:
waf
Here's an example for waf:
(cd $(@D); $(PLUGINPKG_TARGET_WAF) configure --prefix=/usr)
endef
define PLUGINPKG_BUILD_CMDS
(cd $(@D); $(PLUGINPKG_TARGET_WAF) build -j $(PARALLEL_JOBS))
endef
(cd $(@D); $(PLUGINPKG_TARGET_WAF) install --destdir=$(TARGET_DIR))
endef
$(eval $(generic-package))
raw makefile
$(PLUGINPKG_TARGET_MAKE)
endef
endef
Tips and tricks
If using autotools or cmake and you need to specify options during configure, use something like this:
PLUGINPKG_CONF_OPTS=-DBUILD_GUI=OFF
If using autotools without an existing 'configure' script (ie, autogen.sh needs to be run first), use this:
PLUGINPKG_AUTORECONF = YES
If using autotools, cmake or raw makefiles and multiple jobs breaks your build, use this:
PLUGINPKG_MAKE = $(MAKE1)
Compile it
We're all set to compile.
$ cd ~/mod-plugin-builder/
$ ./build eg-amp-lv2
$ ls ~/mod-workdir/plugins/
eg-amp.lv2
Success, the plugin has been built. If you get an error of no-such file or directory, check that you have set WORKDIR the same as when you bootstrapped the plugin-builder.
Final notes
A few important notes:
- If you want to rebuild after a change to your plugin or the .mk then it is often easiest to just delete the previous build's directory for your plugin ~/mod-workdir/plugins-dep/build/<packagename>-<version>
Browse through other examples so you get an idea of variations of project files.
SHOULD THIS GO ANYHERE ??
THIS BIT WAS IN THE CREATING MPB PAGE. DOES IT HAVE ANY RELEVANT INFORMATION THAT IS NOT IN SOME OTHER WAY IN THE ABOVE SECTION AND SHOULD BE INCORPORATED?
Get source code and create a '.mk' file
In case you haven't started your LV2 plugin yet just please follow through the links above in #LV2 Basics.
We have a few plugin examples available here. For this guide we'll use the eg-amp.lv2 example, already included inside of mod-plugin-builder.
Buildroot requires you to create the new mk file as plugins/package/NAME/NAME.mk
- using the same name for both the folder and mk file.
The documentation for this file type is quite extensive, so it's not possible to cover everything here.
On the mod-plugin-builder repository (that you should have cloned before) there are many mk file examples under plugins/package/.
