| 1.8 | 2019/09/17 | Actuator groups; MIDI separated mode; Tempo divider addressings; Actuator lists pagination | Duo: modduo-v1.8.0.862-RC2.tar
Duo X: modduox-v1.8.0.863-RC2.tar |
| 1.7 | 2019/09/16 | Duo X launch; MIDI aggregator; Pages; Redesigned screen menu; User profiles; Unlocked parameters; CV category | Duo: modduo-v1.7.4.854.tar
- do not change BPM when loading PB if sync mode is link or midi
- fix aggregated midi connections on appearing in screenshots
