Troubleshooting
If the Duo becomes unbootable for some reason, we need to reinstall the OS inside.
We can boot the Duo in recovery mode for safe reinstall, boot over USB if recovery partition is broken, or perform a full factory reset (which will erase all your data).
It is possible to make the MOD Duo X unbootable though, if the bootloader or restore partition are corrupted. The only way that can happen is if you remove the power supply during the very small period of the software update when the bootloader and restore parition are replaced, or if you intentionally break them. In such cases it is still possible to recover data, but one needs a imx8mq developer kit in order to boot a custom image/payload (which the MOD team has).
