Revision as of 12:08, 9 September 2019 by Leogermani (talk | contribs)
This page is under construction and applies to devices on version 1.7+
Scroll the options in the main menu by rotating the left knob. Some options have a toggle indicator that can be triggered by quick pressing the left knob. These options have a "[ ]" or "[x]" indicating the state of the toggle. For example, the Hardware Bypass can be turned on or off by pressing the left knob.
Note: You can quickly access the Tuner by pressing and holding the right-hand knob any time.
When you quick access the Tuner by pressing and holding the right knob, you have to press and hold the same knob again to exit.
