| 1.8 | 2019/09/05 | Actuator groups; MIDI split mode; Tempo divider addressings; Actuator lists pagination | Duo: modduo-v1.8.0.833-RC1.tar
Duo X: modduox-v1.8.0.832-RC1.tar |
| 1.7 | 2019/08/19 | Duo X launch; MIDI aggregator; Pages; Redesigned screen menu; User profiles; Unlocked parameters; CV category | Duo: modduo-v1.7.3.780.tar
Duo X: modduox-v1.7.3.781.tar |
- NEW: MIDI split mode (is back)
