| 1.8 | 2019/09/05 | Actuator groups; MIDI split mode; Tempo divider addressings; Actuator lists pagination | Duo: modduo-v1.8.0.833-RC1.tar
Duo X: modduox-v1.8.0.832-RC1.tar |
| 1.7 | 2019/08/19 | Duo X launch; MIDI aggregator; Pages; Redesigned screen menu; User profiles; Unlocked parameters; CV category | Duo: modduo-v1.7.3.780.tar
Duo X: modduox-v1.7.3.781.tar |
- NEW: Actuator groups - NEW: MIDI split mode (is back) - NEW: Tempo divider addressings - NEW: Device options in device menu (Duo X only) - NEW: Paginated list-style controls - Allow reinstalls and downgrades to any valid version - Disable ping/check device every 2 seconds (as it may cause more issues than it solves) - Do not display sensitivity options for Duo X potentiometers - Improve cache strategy for plugin resources (makes loading of web GUI under load much better) - Fix loading pedalboard snapshot referencing a plugin that has been removed - Fix webgui becoming sluggish when midi sync is on (properly throttle events from audio host side) - Fully update parameters and device actuators when transport changes from audio host - Workarounds for Duo X firmware issues with i2c (issue still being investigated) - More miscellaneous fixes and tweaks
