1.7 | 2019/08/19 | Duo X launch; MIDI aggregator; Pages; Redesigned screen menu; User profiles; Unlocked parameters; CV category | Duo: modduo-v1.7.3.780.tar
Duo X: modduox-v1.7.3.781.tar |
