| 1.7 | 2019/08/07 | Duo X launch; MIDI aggregator; Pages; Redesigned screen menu; User profiles; Unlocked parameters; CV category | Duo: modduo-v1.7.2.755.tar
Duo X: modduox-v1.7.2.754.tar |
