| 1.7 | 2019/08/07 | Duo X launch; MIDI aggregator; Pages; Redesigned screen menu; User profiles; Unlocked parameters; CV category | Duo: modduo-v1.7.2.755.tar
Duo X: modduox-v1.7.2.754.tar |
| 1.6 | 2019/07/11 | Commercial Plugin Store; New PB screenshot; Ustable -> Beta; Sharing PB with beta plugins; Display brightness control menu option | modduo-v1.6.3.696.tar |
