| 1.7 | 2019/07/01 | Duo X launch; MIDI aggregator; Pages; Redesigned screen menu; User profiles; Unlocked parameters | modduox-v1.7.0.680.tar |
| 1.6 | 2018/11/13 | Commercial Plugin Store; New PB screenshot; Ustable -> Beta; Sharing PB with beta plugins; Display brightness control menu option; Fix plug-in box shadow | modduo-v1.6.2.614.tar |
Released on 2019/07/01
Pages (Duo X specific)
Quick snapshots (Duo X specific)
Complete refresh of device screen contents
MIDI aggregator
MIDI Clock output (optional, disabled by default)
Transport sync via MIDI Clock Slave
Unlocked parameters
User profiles
